spark plugs
travis37
just wondering how often you guys change spark plugs(hours). could old plugs be causing a high speed miss. I own a 92 175 thats been rebuilt.I plan on changing them but I was just curious.
Dhadley
Re: spark plugs
On my 60* motors I changed them about every year. Just because.
What plugs are you using?
travis37
Re: spark plugs
cham QL77JC4 I was told that I could also use QL78YC NOT SURE WHAT THE DIF. IS.
Dhadley
Re: spark plugs
The 78s are a bit hotter. The Y means extended reach. I use the QL77JC4s in mine. If you susupect the plugs, change them. Yes, it's possible for them to cause a miss. Actually not likely but possible.
travis37
Re: spark plugs
So There Is No Reason To Use The Hotter Plug,just Stick With What Works.ql77jc4
