spark plugs
bassone
I have a 1999 175hp envinrude fitch fuel inj, could someone please tell me what the factory spark plugs are and what should they be gap at, thanks!!
wilde1j
Re: spark plugs
It's not fitch, it's Ficht!
150, 175 Ficht/DI 1997 - 1999 7712 (with non-pinned cylinder heads) .030"
150, 175 Ficht/DI 1997 - 1999 XC12PEPB (with pinned cylinder heads) .030"
Chris1956
Re: spark plugs
Do those Spark Plugs need to be indexed? I had thought so...
wilde1j
Re: spark plugs
Yes, all OMC/BRP DI motors require spark plugs to be indexed.
bassone
Re: spark plugs
thanks for the info, is this something i can do or do i have to take it to the shop, if i can do it, how? thanks!
boobie
Re: spark plugs
If I was you I'd take it to a good shop. It sometimes takes more than 6 plugs to get them indexed correctly and they have to be torqued. The shop should only charge you for 6 plugs as they can be used in another mtr.
wilde1j
Re: spark plugs
I would follow Boobie's suggestion, unless you already have the tools and knowledge to do it yourself, then:
http://www.boatsetup.com/PlgIndexing.html
How to video:
http://www.youtube.com/watch?v=Hi658MThS9o
BTW, never even think of shimming or using extra washers to get a plug to index properly. If a plug won't index, use it on the same cylinder, opposite bank. It will almost always then index correctly.
wallychaser
Re: spark plugs
Hi, maybe some one can help with this one. My 1999 150 Ficht has the Champion 7712's, Im having a hard time finding them. I was given a replacement equivilent, NGK PZFR6F11, this was right on the retails system computer as an alternative. I diidnt go with them...yet... Should I keep looking or will the suggested replacement work?
Nick
wilde1j
Re: spark plugs
Nick
I would only use the recommended Champions.
