Spark Plugs
mike165
What would be the best plugs to use in my 250 cu in L6, 165,comp is good 130 psi avg,and using no oil
Bt Doctur
Re: Spark Plugs
The ones that fit ,there were 2 different thread sizes. What were removed?
ziggy
Re: Spark Plugs
check out the mercruiser service manual that applies to your rig. in the specifications sections you'll find what the proper plug to use is... in my case, for my '75 mercruiser 165hp, L6 250 cid i use ngk br6fs (ac mr43t). i like ngks generally speaking... use what the s/m says though. the s/m is all knowing for your application.... ;)
