spark plugs
badpfddexter
i have a 1995 evinrude 175 @i keep fouling plugs<br />i have tried different plugs it will rev up fine <br />but will not get up on pad
ob
Re: spark plugs
What plugs are you using? What type of fouling are you seeing? Oil fouled ,deposit fouled,bridge gapped?Your problem may be carburetor or ignition related,but I can't run with that ball without more details.If your engine is the 60 degree block 175 ,it calls for Champion QL78YC gapped at .030".
badpfddexter
Re: spark plugs
i put new plugs in and run it the 3 on the left side are black and smell like gas and the 3 on the right side are like new.
DHPMARINE
Re: spark plugs
brad21,<br />Are you saying underload you are getting the RPMs but cannot plane?Or does the engine rev okay in neutral,but doesn't have the power to get on plane?<br /><br />If reving okay in neutral,but a power problem exists,do the basics:spark,compression,fuel sample.<br /><br />DHP
badpfddexter
Re: spark plugs
it will rev ok in neutal but no power i put new plugs in and went down lake fine but comming back i was at a slow troll and thats when it happend it has happend 3 times
badpfddexter
Re: spark plugs
badpfddexter
Re: spark plugs
badpfddexter
Re: spark plugs
badpfddexter
Re: spark plugs
Walker
Re: spark plugs
Like new plugs on one side sounds like you lost ignition to that side. Could be power packs, shifht interupt switch or something else. You need to determine if you're getting fire to all 6 plugs when the problem happens.
