Re: sparkplug wires
As long as they are solid core wires, yes. There are two screws on the tpo (Bottom when on engine) of the distributor cap, one an either side of the center coil wire. Unscrew those two screws and the lid will come off the distributot cap along with a rubber sealing gasket. The wires are a tight push fit through the gasket. The wires will plug into prongs in the other part of the distributor cap. Firing order is 123
