branman1971
- Joined
- Jun 2, 2007
- 59
I recently bought a 1997 Crestliner 20ft pontoon that came with a 1993 Force 70hp. With the Force, I could only get 12-13mph (gps) at about 4100rpm (WOT). I swapped the pontoon motor with the motor that was on my 16ft MFG runabout (which is a 2003 Yamaha 70hp 2 stroke,) and only got up to 14-15mph. The Force 70 runs my 16ft runabout like a raped ape so I am happy there, but I would like a few more mph on the pontoon for pulling tubers on the way out to the island and back. I have not hooked up the tachometer to the Yamaha 70 yet but I plan to tonight. I also plan on looking to see what the pitch of the prop is. The Yamaha's 3 blade prop is considerably bigger diameter than the Force's prop but I was told by a local repair shop that if my prop is wrong, and it is preventing the motor from spooling up, and it is creating a lag, it could blow the motor up. Ok, so now i am concerned. I was told normal operating rpm's should be 5000 to 5500 WOT. Is this correct? If my prop is not letting me get 5000rpm's, what do I do then to determine the correct prop to go with? Thanks
