speedifour rpm gauge.
ctaylor2069
1963 speedifour 75 HP. Which wire is used for the rpm gauge? Does anyone have a wiring schematic? Or tell me how to wire it up. Thanks
boobie
Re: speedifour rpm gauge.
The only tachs I can remember back in those days attached to the spark plug wire. I'm sure somebody will correct me if I'm wrong.
F_R
There are two black wires connected to the "M" terminals on the key switch. One goes to the post on the side of the magneto, and the other one is grounded at the powerhead. The tachometer connects to the one that goes to the magneto. Simple way to tell which one that is....try connecting to one, and if it doesn't work, must be the other one. 50% odds ain't too bad.
Having said all that, the motor requires a tachometer for a magneto motor. Nobody makes them any more. Modern tachs won't work on it. One exception is the Tiny Tach digital tach that gets its signal from a spark plug wire.
ctaylor2069
My boat has a tac already its a 72 sportso do i craft . I'm hoping that it works. My tac has 2 wires coming off it I'm assuming I connect one wire from the tac to the magneto and other to m terminal? Sound right f_r
