Re: speedo operation
Puddle, The speedo is a water pressure guage, fo rall practical purposes. Mount the Pitot (pickup) so that it will be in the water at all times. I had to move the Pitot on my speedboat closer to the motor, so it would be in the water at high speed. No real magic to the angle or height, just so projects below the bottom of the boat at all speeds.
PS these are known to be inaccurate. You might check your speed with a GPS to calibrate the speedo in your mind.
PPS - if you make the pitot hole larger, your speedo will reader a higher speed. Do you think the boat will really go faster?
