My Uncle just bought a 1997 Welcraft/Excel 19' bow rider, with a Volvo/Penta 4.3 GL motor anda Cobra outdrive. neither the speedo or Trim indicator work. <br /><br />I think the speedo is probaly clogged, but before I do something stupid, I will ask. On the transom there is a white do hicky?? I think this is the speedo pickup, it looks like there should be a 1/16" hole in the end that is cake with mud. where it mounts to the transom, it looks like 1/8" tubing going up and then thru the transom. I do not think it is the transducer, I have not found that yet, It is mounted way to high, and looks way to thin. Do I run a wire to clean the mud out? <br /><br />second question, How can I test the Trim Gauge to see if that is bad, and how can I find and test the trim sending unit? <br /><br />If the Transducer for the depth finder is a Shoot thru the hull type, where would I find it? (I know in the bilge, and just look!!!) <br /><br />I have only seen the boat once, 2 hours in the water and 5 minutes at the ramp. So i know some of the questions and descriptions are very lame, but tomorrow night I am going to try to help hoim trouble shoot some of the minor problems.<br /><br /><br />Thanks in advance for any help.
