speedometer not working
roger56
Trying to help brother his speedboats speedometer quit working. Looked under dash everything looks connected. Cable seems to go to back of boat. I have no idea where it is suppose to go from there to Motor or some where else? Motor is a vlvo penta inboard about four years old. You guys have all the answers thanks for any help.
Re: speedometer not working
Ayuh,.... That cable is actually a Hose, that goes to the pitot tube on the transom,...
the gauge senses pressure...
dypcdiver
Unless it is an electronic one!! with a paddle wheel, in which case make sure the paddle wheel is free to turn.
Don S
Since you didn't see fit to tell us what engine or drive you have, I will assume you have an SX-A. If that is the case, check the leading edge of the drive and see if the pitot hole for the speedometer is plugged up. Also make sure the hose is connected and not pinched.
roger56
Thanks guys will check it out and ley you know my brother is a little ADD he has some limitations.
