speedometer problems
hey I have a boat that we are carpeting foaming and fixing chewed wires and for our speedometer there is a weird plug its like 4 wires electrical taped together and they all connect to this plug and it has 5 holes like another half would plug into it but there is no other half any one got any ideas
The speedometer is labeled 1-6 also
gm280
Re: speedometer problems
Pictures, pictures, pictures... We can't see what you see, so you have to supply pictures so we can give advice or suggestion.
And welcome to iboats... :welcome: Good to have you aboard...
Post some pictures and more info and I'm very sure you will receive ideas and suggestion from a very knowledgeable forum of boaters...
Ayuh,... Welcome Aboard,.... Whatcha workin' on,..??
Most boat speedo's are Water power, 'n not electrical, at All,....
Well,... 'cept for the light,...
GA_Boater
I think you are looking at your tachometer. Tachs often have a selector switch to match the tach to the motor. Speedos seldom have wiring except for a light.
What kind of power - Mercury, Johnson, Mercruiser, etc.?
Silvertip
You are looking at the Tachometer, not a speedometer. At the bottom of the dial you will see a label that indicates "x1000". Since the dial is calibrated 1 - 6, that means 1000, 2,000, 3,000, 4,000 xxx, 6,000 REVOLUTIONS PER MINUTE. The tach indicates how fast the engine is running.
Silvertip
What makes you think that plug connects to anything. Lots of boats have one or more spare plugs -- usually carrying +12 volts, ground, and perhaps a light circuit. We have no idea what boat you have but most instruments, tachometers included on older bolts do not have plug-in connections. There are screw terminals on the back labeled "I" (12 volts with the key in the RUN position), "L" (+12 volts when the navigation lights are on, a ground connection, and for fuel. temp, tachometer, oil pressure gauges there is an "S" (sender) terminal that connects to the applicable sender on the engine. For the +12 volt, light and ground connections you can connect to the same terminals on any other gauge.. The sender connection comes from the engine harness.
