speedometer replacement ???
WAVENBYE2
My speedometer is acting up, it showed 35mph when I know I'm doing at least 45-50mph, no engine probs. at all. Is there a way to pressure test it? The tab on the stern looks to be original and maybe worn can I replace just that? Any advice would help Thanks ...Pat
Silvertip
Re: speedometer replacement ???
How many other places did you post this question? Check the other one for a response.
WAVENBYE2
Wasn't sure were to post it, Using the other thread posted THANKS>>>PAT
Scout Sport Fish
Speedometers are well, not always an accurate thing. Its jus thre nature. Mine will say im going 4 MPH when Im at WOT.
Coors
find the piece of crap plugging up the pitot, then blow air from the speedo, thru the tube
scoutabout
I whacked a semi-submerged and very punky chunk of wood with my Alpha outdrive several years ago. Immediately after my speedo stopped working. I discovered the pickup or pitot along the leading edge just above the prop got all plugged with soft wood. Careful picking and poking with a pin opened it up again and the speedo once again worked.
WAVENBYE2
Ok, thanks guys, Will do every thing that you all advised>>> :cool:
