Speedometer
AlyEli2
I have a 1984 Skeeter boat with a 1985 Force 85hp motor, does anybody know where I can get a speedometer and a tachometer (rpms) for my boat? Do I have to get them to match my motor?
Thank you for your help,
Mark
thomasf36
Re: Speedometer
Mark
usually tachometers are fairly versitile but if you use one that isnt for your boat it should be accurate. as far as speedometers go i would try west marine or just search it in google or bing.
sid007
Re: Speedometer
West Marine, bass pro. Just find a good place to rerun the cable and mount the speedometer.
Just FYI a good GPS will do speed as well and the iPhone has a marine application that works very well for $4.99
chitownborn
Re: Speedometer
if you have the prestolite ignition[ modules & coils] youll need a twenty pole tach, no other one will work, the only one i know of is the red international and they also have a matching speedo, i got mine at overtons.com good luck don
AlyEli2
Re: Speedometer
Thank you for all of ya'lls help thank you very much. I will look into all of the advice. Again thank you
Mark
MN-WaterGuy
Re: Speedometer
If you've got an iPhone, there are now free apps that are extremely accurate.
