Re: speedometer
Ummmm -- better make sure you have a paddle wheel speedometer. Stick you head under the console and look at the back of the speedo head. If you see a plastic tube in the center that tube runs to the back of the boat and connects to a speedometer pickup called a pitot or it connects to the lower unit on the engine which has a built-in pitot. The paddle wheel is probably for the speed indication on the fish finder. If there is another plastic pitot on the transom that sticks down slightly below the bottom of the boat, that tube connects to it.
