Speedometer
joshstan1978
I have a mercruiser Apha One Gen One that the speedometer quit working on. I don’t want to replace with a gps unit kinda just trying to learn about boats. There was a pinch in the line running between the speedometer and the plastic intake mounted on the transom. I fixed that and air blows from the tube by the speedometer and the plastic white pickup sensor (terminology??) on the transom. Still just stays at zero and doesn’t move. I have tried checking the out drive but I can not find the hole one mine. Is it because it’s a gen one??? It is not on the front edge of the out drive. I can not find a hose running up through the out drive like a gen two. What do I try next ?
joshstan1978
That’s what I was wondering. Is there a way to test the speedometer to see if that’s the issue?
joshstan1978
But it would tell me if the needle moves. Great idea. If it doesn’t move is that a sign something failed in the speedometer itself?
nola mike
Pitot.
Gen 1's have don't have a speedo in the drive. Should have a stand alone pitot on the transom. They're pretty fragile. Google an image.
get a small bit of hose. connect directly to the speedometer. you should be able to blow into the hose and get about 5-10 mph on a pitot tube speedometer.
couldnt post the pic of the speedo calibration, so I typed it.
If adjustable air pressure is available, standard calibration speedometers should react to the following pressures:
5 psi = 20 mph, 11 psi = 30 mph, 19 psi = 40 mph, 30 psi = 50 mph
