Re: Speedomoter not reading correctly????
Get your hands on a guaged pressure tester. Mighty vac comes to mind. Adapt it to fit into the speedo tube that comes out of your lower gearcase and pump it up to 5 psi.Should read 20 mph and hold that pressure without leaking off.If it leaks off you have a hole in the hose or the speedo diaphram.If all looks good there then the pickup is at fault.
