Spilled Gas
MNMARK
Well here I go again with another dumb question. I was filling my boat, and I spilled about 3 cups of gas on the carpet, which worked its way down into the bottom of the boat. I turned on the pump and got most of it out but I still have the gas smell. The good news is my wife wont go out on the boat till I get the smell out, the bad news well come to think of it there is no bad news. Any ideas?
flycaster
Re: Spilled Gas
Bad news is where there is the odor of gas there is the possibility of an ignition of the gas fumes with the proper electrical spark!!
MNMARK
Re: Spilled Gas
Sorry I should add to my question, I used the wet vac and got about 95% of the gas up, and watered it down and i think i got the rest. Its the oder i cant get out. Also I would never pump gas into the lake! I pumped the water I used out
a70eliminator
Re: Spilled Gas
A dead fish in the boat for about a week should take care of that gas smell lol. Seriously, rinse the bilge out really good with some **** and span, if your on the water then something environmental would be appreciated, the odor of gas usually goes away after it evaporates.
Ironic that I had no idea I was saying a bad word until the edit made me stop and think about it.
Summer Fun
Banned
Re: Spilled Gas
Say that you really DIDN'T do that !!!.:eek: . :eek: . :eek: . :eek:
You're lucky that you didn't go Kaboom !!!!!. :eek:
Mark42
Re: Spilled Gas
People blow themselves up regularly using a shop vac on gas. Guaranteed bomb. You are lucky nothing happened to you. Never vac up any flamable liquid with a shop vac.
Doernuth
Re: Spilled Gas
Leave it out in the sun uncovered and open and let it evaporate. It will go away eventually. Run a carpet cleaner over the carpet also.
gonefishie
Re: Spilled Gas
Speaking of a dead fish in the bilge. I wonder how long Huron Angler's boat smelled? :D
cougar1985
Re: Spilled Gas
pull plug,add i quart of ajax ,let sit then wash out ,all done.shop -vac ,badnews ,luckily you didnt get to experience a moving experience,boom!.glad to hear your still ok.
tx1961whaler
Re: Spilled Gas
Denatured Alcohol will get rid of the smell.
So will Seafoam, but that's kind of expensive to be dumping around.
j_martin
Re: Spilled Gas
It needs to be explained that the air a shop vac pulls through, goes through the series wound motor, sparking carbon brushes and all.
Man, oh man, you better go get a lottery ticket. You should have blown off an arm and burned down your boat.
tx1961whaler
Re: Spilled Gas
We can turn this into another ethanol thread:
"Darn ethanol won't even explode a shop vac into a raging fireball because of phase separation !!";):D
bruceb58
Re: Spilled Gas
This post need to be moved to the "stupid human tricks" section.
