Spindle Lube Drive Pin
lazydawg
I have a problem with my spindle lube system on my trailer. The brand name is super lube I think. The castle nut was held in place by a drive pin through the spindle. After I completed a bearing replacement I discovered that cotter pins won't work as a replacement because they don't seal off the hole through the spindle. Instead of forcing the grease to the back of the spindle, it just comes out around the cotter pin. i haven't been able to find a substitute yet that will fit the hole tightly and still be flexible enough to bend. Does anyone have any experience with this problem?
bobingardner
Re: Spindle Lube Drive Pin
Hi lazydaug,<br /><br />I wish I could help but all I can do is suggest you browse your local hardware or try a google search. "super lube spindle trailer" brought up some hits.<br /><br />Good Luck<br />bob
Most Hardware stores,+ Auto Parts stores will sell you Roll-Pins........
