My 1996 Johnson 112hp slp was froze up/ stiff. A little lube( BP BLASTER) in the cylinders and it started to turn freely with the pull rope. I can spin the unit with a pull rope and or the starter with no problems with out he plugs inserted. When the plugs are installed I can not get the starter to turn the flywheel and or pull with the rope What is going on? Stuck valves? What to do? Is there a FOGGER that would free everything?
I had light brown fluid in the cylinders, I think there is water in the tank from a leak in a gasket . I switched to a three gallon portable tank with new gas,
