Esox
- Joined
- Sep 14, 2006
- 288
I'm almost done with the transom replacement, Just a few things to finish up. I ordered these aluminum drain tubes for the splashwell drains.
http://www.iboats.com/Drain_Tubes/d...d.217452--list_time.1192201670--view_id.39188
It turns out these are 1/2" too short for the thickness of the transom. It seems the only thing I can find that is long enough is Brass - not aluminum. Would it be ok to use the Brass instead of the aluminum? Will it cause corossion?
