Re: Splicing Transducer Wire
Yers, I have spliced coax on transducers more than I care to.. but, I have used the type of splice connector your local cable co. uses in your house for an old flasher unit.. it works well.
Also, I have spliced the newer Humminbird LCD type by
A: Staggering power/grnd wire splices. ( as someone else mentioned.. makes a more streamlined, neater repair)
B: save as much of the shielded material as possible to re-wrap shield splice... add aluminum foil around the shield repair if necc. ONLY the shielded wiring.. don't throw the power grnd wires under it, if possible.
C: waterproof this whole repair as best as possible.. green corrosion LOVES wiring repairs.
The " Bertram Yacht crowd" I've had the pleasure of meeting on this electronics forum might chastise you, because you didn't get the servants to run down to the Marina and buy a new transducer/cable assembly PRONTO, but this repair can be done cheap, effective, and permanent.
Bob List
