trobinson017
- Joined
- Sep 12, 2004
- 183
Hi all, I thought I'd posted the problem before but I couldn't find it so reposting.
My Johnson 130 OceanPro outboard started having a problem with consistent running.
It idles okay and runs at low RPMs okay. But once I go to half throttle or WOT it starts
acting up. At half throttle it will level off at a lower RPM, then jump up to where it should be and then
back down. If I try to go WOT it won't even generate half the RPMs it should for about 10 seconds, but it will
suddenly jump to normal RPMs and the boat will speed up accordingly, then it drops back down to
about half power/RPMs. I'm running off of a 6 gallon external tank and have checked the intake there,
the fuel line, the fuel filter, etc. I took the carbs apart last month and everything looks/works fine.
A mechanic checked the fuel pump last fall for a different problem and that was okay then. There's no
water in the fuel. Fuel filter is clean. I just can't figure out what to check next.
Any ideas?
Any ideas?
