reelfishin
- Joined
- Mar 19, 2007
- 3,050
I just picked up what appears to be an early 60's boat, a Sport-Craft Ski King.
It didn't have a trailer but came with a running motor, a 1965 Mercury 85hp along with a full enclosure and top.
The hull is in great shape, the floors and transom are solid.
My question is for one, were these things even capable of handling such a heavy motor? 85hp seams a bit excessive on a boat this size.
Second, what should this hull weight?
I pulled the motor off, with intentions of hanging a newer Johnson. I also will be setting up a trailer for it.
How much do these normally weigh? It's now all but a bare hull and it feels like it weighs around 1000lbs or so. There is no foam flotation, the deck to hull area is only about 3/4" thick and it's all original from what I can tell.
The hull measures 15' 8" long, the beam width is 74". The glass is heavier than most but not so much that would justify the weight. I did several drill test for water logged wood but all looks fine. It was stored indoors in a barn for the last 30 years or more. Other than being covered with dust, its in great shape.
Compared to my Glasspar, which is the same dimensions, this thing is more than double the weight.
Two guys can lift my Glasspar on and off it's trailer, two guys can't even lift one end of the Sport-Craft.
I can find no info on early Sport-Craft boats, this one looks to me like it may be either early 60's of even late 50's. There is no foam, the dash looks like a 50's car, and the steering wheel is cast aluminum.
Does anyone have any experience or info on early Sport-Craft boats? When did they start making boats?
I had a Sport-Craft camper years ago, it had the same plastic name plates on the side and was only about 12' long. It was one of those tear drop shaped campers from the 50's. It was even the same color as this boat, aqua blue and cream white.
