Sport Jet 90 ignition troubleshooting
Daremo
As I had a bad stator and it was cheap enough to do, I have replaced the entire ignition system with the Crowley Marine discounted CDM system which updates this 1995 motor up to the 1996 ignition or the Sport Jet 95 ignition system as its called in the manual.
I still am not seeing any spark.
I have verified the following according to the service manaul.
Stator - 710 Ohms between Wht/Grn and Grn/Wht. (should be 500-600+/- 10% but 50 ohms isnt a big deal)
Trigger - Should be 1100-1400 between Wht/Blk and other 3 trigger wires. All 3 approx 1200 Ohms.
CDM module for Cyl one
Pin A to Pin C - Should be 1250 +/- 100 Ohms. 1280ish.
Pin D to Pin A - Diode test on fluke. Continuity indicated which is correct.
Pin D to Pin A - Diode test, reversing leads. No continuity which is correct.
Pin D to Pin B - Diode test. No continuity, which is correct.
Pin D to Pin B - Diode test, reversed leads. Continuity which is correct.
Pin A to Spark Plug Terminal - 1070 ohms (should be 1050 +/- 150 ohms, so its good also)
I just noticed that the manual does mention that you should check all 3 CDM's, so I will check them all for resistance and diode tests. I cant perform the voltage tests because I dont have the testing harness and I dont want to cut into the wiring.
I have isolated the Rev Limiter by completely disconnecting it, still no spark, and I had previously checked the safety lanyard switch, which I will check again.
I have replaced the ignition switch as I had never got the keys to this boat, so just bought a new one. I *THINK* its wired correctly, the engine IS turning over, but thats a possible area I have to double check as well.
So I'm running out of ideas as to why it wont spark. Any suggestions? The ONE other thought I had was the flywheel might be wrong, but CDI specs a replacement stator that fits both this ignition system and the previous one, so I am thinking they are one and the same.
Also is the PWC forum better for this motor?
Thanks!
Rob
