Hello all, Allow me to introduce myself. My name is Tori, and i'm coming here to ask a few questions regarding the SportJet 90 (Merc/Force) engine and Jet unit. I am trying to transplant this combo into a vintage PWC. I'm attempting to put in a Wetbike. I have lots of experience with vintage PWC and have done a few engine swaps before so this isn't anything new to me, bu this motor and jetpump are.
I know this isn't a highly loved engine, but i'm very limited on physical size and engine/jet pump options. The Wetbike came with an almost identical set up, so this isn't too far fetched. The Wetbike came with a Suzuki DT50/60 2 cyl. perched atop a similar Jetpack. In fact the thru-hull is identical. I've managed to shoehorn the 3cyl. Force motor into the hull, and the only thing at this point fouling things up is the water supply line that runs from the engine mounting plate to the engine. I lack about 3/16" of the fitting on the block clearing the hull.
Question: Can i downsize this fitting and supply line. Its a very large hose, maybe 1" O.D. From my experience, i can't see this motor needing or using this amount of water to keep it cool, but i want to be sure. I might be able to downsize to 3/8" i.d. and solve my problem.
Here are a couple pictures of what i have going on.
