Sports jet 90 bottom carb leaks
wvblazer
posted June 18, 2006 03:55 PM <br />--------------------------------------------------------------------------------<br />I have a sportjet 90 power head that has had the carbs rebuilt two times. Both time float and needle valve has been replaced but it still leaks gas. Any ideas or some one that may have rean into this. Help wold be greatly apreciated.
studlymandingo
Re: Sports jet 90 bottom carb leaks
Have the float levels been properly adjusted? If so, then sounds like the seat could be dirty or pitted.
Capt Ken
Just in case you don't check your post in the other section, the vents are clogged on the side of the carb. Common problem.
