Sunsetrider
- Joined
- Jun 12, 2011
- 299
I am replacing the drivers lounge seat with a pedestal seat, so before I begin that process I decided to address the soft deck area around the port side of the ski locker. I've sliced and peeled the carpet back and ripped up some of the waterlogged decking. I am pleased to find the stringer and foam solid and firm, although there is about an inch of brackish water down in there. The wet decking is not too extensive in area and I'd prefer to cut-and-fill with 3/4 fir 1SG, epoxy barrier and fiberglass top, roll the carpet back and screw the port lounge back in place.
So far I see no evidence as to how the decking has been attached to the stringers. Would I be correct in simply screwing it down into the stringer(s), perhaps taking the precaution of pre-filling the pilot holes with epoxy?
Secondarily: Is there any special trick to cutting out the section of decking? So far I am trying the skil saw, but it isn't happy when it hits the good fiberglass . . . I am not particularly carpentry-skilled, but I do try from time to time.
