Hi,
I tried to do a search but couldn't find exact answer to my question. I just bought a 1968 Lund S-14 and would like to re-paint the upper part of the hull and the inside of the boat. I have done some some research and think I understand that I can sand the parts that have the original paint and that I need to use a self-etching primer on the bare aluminum parts.
My question is, is it ok to get some self-etching primer on the original finish? Using a rustoleum type spray can self-etching primer I can't see how I won't get overspray onto the orginal finish. Or do I need to get self etching primer in gallon size and use a brush to be more precise? The inside has a lot of small (1 inch type) scratches in the original finish. I wasn't sure if spot spraying self-etching primer over the orginal finish would cause any adhesive issues with the top coat.
I would prefer not to sand the entire boat to bare aluminum. I don't think I have the time for that. I have attached a picture as an example of the outside of the hull.
Thanks for any advice!
Kyle
Kyle
