I'm fixing to replace the floor in my fishing boat, and I would like to apply a gel coat to complete inside of the boat so the colors match. My limited understanding of this process is simply to add pigment to the polyester resin, then spray it with a spray gun ($50 siphon feed from Home Depot). Does it need to be sprayed, or can you mix up a batch, dump it out, and spread it with a straight edge of putty knife? Should all the surfaces receiving the gelcoat be scuff sanded and how much? What do you use to clean the spray gun? Are there any good books or videos to buy on this subject? Thanks for any responses.
