there is still 1' of snow on the ground, but i'm getting the itch to take the cover off the boat...<br /><br />I have twin '88 150 carb'd motors and I'm planning this spring's maint and shopping for parts. I've had this boat for 1 yr, it ran beautifully last season and it was professionally maintained before that. I'd like to save some $ by doing this myself and learn a little about the machines. I have the Clymer manual but it seems lacking in places.<br />I was planning on doing the following. I have searched this forum and found lots of great info. I still have a few questions that I couldn't find answers to. Am I missing anything? What do you all do that is different? Thanks for your feedback!<br /><br />Cooling system<br />-Replace water pumps (lower unit fluid change was done in the fall, will it need to be redone when lower is dropped?) I think the water pumps were last replaced 2 or 3 years ago, so lower unit should come off ok. There are burn marks where the heat wrench was used last time. I know this task can be tricky, are there any good hints or tricks? I've found some of rodbolts posts on this subject for newer models, I assume they apply for the older ones as well? <br />-Tstats and poppit valves (check, clean or replace)<br />-Is there a good way to clean/flush cooling passages without pulling heads etc? Can mineral deposits be dissolved with some kind of solvent?<br />-Maybe install a water pressure guage or temp guage, is one preferable to the other? anyone have both?<br />Fuel Sys<br />-replace Racor elements<br />-is there a way to check fuel pumps? or should they just be replaced every few years? what about just replacing the diaphram(s)?<br />-what should be done with the carbs?<br /><br />Oil Injection<br />-pull and clean remote tank pumps and filters<br />-what should be done on main (engine mounted) tank?<br />-check warning light/alarm circuits<br /><br />I plan to do a compression test, last year all 16 cyl were 110 +/- 5. I'd like to do a leak down test also - how is that done? What special tools would I need?<br /><br />Is it a good idea to de-carb at this time? Maybe it's best to do it before I put new plugs in? Is it worth doing if there is no apparant problem?<br /><br />In general, after many hours reading this site, it seems most catastrophic engine failures are related to overheating, oil starvation, or lean condition. I'd like to get ahead of anything that would cause one of these problems later. I'd like to get a few more years out of these motors.<br />THANKS for any feedback!
