Spring Shakedown Cruise
Gary H NC
Well,hooked up,batteries charged and ready to go.
Forcast of 80 degrees tomorrow....
After thinking about the ton of work that i done over the winter i'm trying to think if i'm forgetting anything.
Re-sealed outdrive and refilled,Shift cable adjusted.
New carb,Complete tune up.All belts and hoses replaced. New bellows,new gimbal bearing.Everything greased.Replaced impeller,
Oil changed and new fuel filters.
New bilge pump,new switch for it.
New fuel gauge.
New trim pump and motor.New trim switch.
New Stiletto ss prop.
Not to mention all new seats...
Geeze!! It better run good!
Hooked up the muffs in the driveway,She fired with a bump of the key.. Heading to the lake in the morning8)8)
tashasdaddy
Re: Spring Shakedown Cruise
did you test all the equipment, hell of a note if bilge pump doesn't work, PUT THE PLUG IN. have a good season.
Ayuh,..........
Don't Forget the Plug.............
Gary H NC
Yep,Tested the pump. There was an old 500gph pump.I got rid of it and went with an 1100gph. I still think that is small for a 19ft boat but its a big improvement over what was in there.. Thinking about putting the 500 back in too..
I will remember the plug! ( I HOPE)...8)
