capslock118
- Joined
- Apr 27, 2009
- 249
Hi All,
This post may be an over analysis and a waste of time but I just wanted to summarize my observations in case something doesn't sound right here.
The engine turned on immediately, hooray!
Few things that I noticed were:
1: The engine was idling at 3,000 RPM. I THINK i remember idle last year was somewhere around 1500 to 2000 RPM after my local mechanic tuned the engine up. Does this sound normal or where can I go to answer that question (1990 V6 135 HP blackmax)?
2: The engine ran a 30sec to a min before the water impeller kicked in. I thought this was an unusually long time, but it seemed functional once it started going
3: The engine heated up to about 182 degrees F. I THINK I remember the engine running less than 145 degrees last year (145 is the center of the temp dial) but maybe I either forgot completely OR the hose water was not cold enough, either way it was stable at 182 at idle temps. The overheating sound starts going off at 220 and it didn't get that hot.
4: The battery was @ 16.5v when I finally shut the engine off I'm not sure, but I feel this is high. I thought batteries ran at 12 or 14v? It's a brand new deep cycle battery 1000 cranking amps 105 reserve min. I wasn't paying that close attention but I thought the battery was at 14v when I first started the engine. That said, is the engine running at 3k rpm idle because it's working hard to charge the battery? If so is it overcharging it and is that potentially dangerous?
Spring tune up this year consisted of:
-New fuel pump diaphragm
-New fuel/water separator (boat never had this installed before)
-New fuel line
-New tc-w3 oil (west marine)
-New lower-unit oil
Thanks for your reviews
-New fuel line
-New lower-unit oil
