meyerboy, Isn't that really asking a drill to do more then it can? Unless you are gearing it down to get more torque out of the drill, corded or cordless, I can't see it turning over any size OB engine myself. And if you are going to rig up something to gear it down, isn't that then actually a starter motor? JMHO!
Meyerboy - How often do you try to start a fogged motor?
If you have difficulty because of the fogging oil, remove the spark plug and yank on the pull start a few times to clear the oil. Put the plug in with a few drops of pre-mix in the hole first and a couple of more yanks and the motor will start - As long as it's tuned up. No inventing needed,
