Spun a hub?
Jkovalcik
So I had some trouble installing the lower unit on a Mercury Thunderbolt 115 after replacing the water pump. I was unable to find the correct gears. I put the lower unit back on correctly and the propeller spins as it's supposed to (F N and R) hooked to water muffs. I took it to the lake and it moved the boat in reverse as it was supposed to but when I put it in forward the boat would not go anywhere but I could see water churning and the propeller moving faster as the motor idled up but it would not push the boat forward. Everything is the same as before besides the new water pump. Did I spin a hub? When I get home I'm going to try and mark it and see if it spins.
flyingscott
If the propeller is moving the boat should be moving.To check for a spun hub scratch a line across the back of the prop across the hub and run it and see if it moves. My guess is you did not align the shift shaft correctly. Look at the sticky at the top of this forum for the procedure to align the shift shaft.
