Don Crandol
- Joined
- Dec 12, 2004
- 8
1997 Sportcraft 232, 5.7, Alpha I Gen II thunderbolt V ignition.<br />Apologize in advance for the long post but would like to explain the whole situation.<br />Oil pan Started leaking at the end of the season last year. Decided to pull the motor this spring and replace the oil pan. Although the motor was running good, ran compression check before pulling the motor in case I had a problem that I should take care of while the motor was out. Motor has 800 hours in salt water. All cylinders between 165 and 180. Pulled motor, replaced oil pan, complete service on outdrive. Reinstall motor, tune up. Motor had a slight miss on the muffs. Put it in the water and under load would not run above idle. Thought I had crossed plug wires but was not it. Put on the old distributer cap, no change, old rotor button, miss gone. Turns out that the rotor button in the tune-up kit was for a V-6 not a V-8. Anyway took out for a test run and it started losing power. Water temp never got over 150. Back to the dock, pull plugs, electrode completely gone off # 5 plug, compressiuon check, no compression in the #5 cylinder, # 3 down to 70 psi. Pulled heads Both head gaskets blown and the #5 exhaust valve tuliped. Heads machined, reinstalled, fired up ran good at idle. water temp at 150, oil pressure at 40. Take out for a test run still not running right, get back to the no wake and throttle down and oil pressure drops off to 0. Pull motor, tear down, spun main bearings. Question is, is this all related to the wrong rotor button, or should I be looking for another problem. I'm fairly certain it was the problems with the heads but not so sure about the bearings. Any thoughts?
