david_r
- Joined
- Aug 11, 2008
- 1,118
i have lost a few mphs and i break traction when i go to power out of a sharp turn....... i only gain 2-3mph between 3/4 and wot...it used to be very noticeable when you hammer down from cruising speed
i marked the prop as per ezeks method and it is slipping.
what has me confused is i thought i would loose my hole shot if the hub was spun.
is this normal to still have a good hole shot???.....if it was any better my lil boat would practically jump out of the water.........of course that would be ok with me too
it is a '79 johnson 115 with a 13x19 cupped prop .... factory prop..and im pretty sure its stainlesss
i havent put a stopwatch to it but i gets up on plane in seconds.
