Greetngs to all and thank you in advance,
Last season I spun the prop on my 1989 yamaha 150 pro v , 3 times. Researching the issue I found that repeated spun props are generally caused by overheated exaust. I am assuming this is correct?? If the cooling system is working correctly, What other reasons are there for over heated exaust? Is the trim tab used to provide more water for cooling? Currently there are 160 degree thermostats installed, are these correct? Do I need to add a low water pick-up unit?
I am completly baffled. Any help would be greatly appriciated.
Best regards,
Brian
Best regards,
Brian
