Hey, I'm pretty sure I have a spun prop hub. I just bought the boat, and the prop is pretty dinged up, so I figure I should go ahead and replace it and be sure everything is working right. I'm running an 1988 OMC 4.3L with OMC Cobra. I've spent several hours trying to answer the questions below, but I'm very new to boating and it's a bit daunting. I figured it'd be best to ask for some expert advice.
I have several questions:
My other threads regarding the boat are here and here.
- Could anybody please advise me on which prop and hub kit I should consider? Currently I'm thinking Aluminum to try to keep the cost a little lower.
- I read that there are some props that allow the hub to be exchanged more easily in case of failure. Is this a good way to go?
- What pitch/diameter should I be looking at?
