Hello,<br /><br />I did a little search on the forum on the subject of spun props. The consensus is that it is a good idea to carry an extra prop in case one hits an object and damages the prop or hub. I was out the other day and tried to imagine changing a prop on my '98 25 Mariner OB while out on the water. There are lots of ropes in the area of the bay that I go and entirely possible to tangle one's prop in a rope. The old motors that I am used to had a split ring or shear pin that would break if an obstacle was hit and there was no moving until it was fixed. A tow to shore by another boater was the fix. Thankfully have never had to do it. <br /><br />Have any of you made this repair at sea? I have never spun a prop. Is it fair to assume that they will still operate at low speed even after hitting an object? Is the rubber hub the only protection that the motor has? i.e Is there anything else that "gives"? <br /><br />I can imagine the "sinking" feeling I would have in trying to do this on the water and having the bolt or prop fall out of my hands while leaning over the stern. <br /><br />Thanks
