Spun Prop ?
I was out on the lake today, motor (125 force) was running fine all of a sudden the boat started to slow down and the rpm's started to go up. I throttled the motor down and tried it again with the same result. Limped it back to the dock.On the way back, the motor seemed to run O.K. at low speed. Back at the dock I checked out the motor, nothing seemed obviously wrong.I tried moving the prop to see if it meant have spun, but it seemed pretty tight. Could it be spun but still tight enough that I couldnt move it by hand?. Maybe only breaks loose under power?.<br /> Thanks
Trent
Re: Spun Prop ?
Make a mark across the prop hub with a waterproof marker. Go try it. If the marks move then carry prop to a prop shop and have it re-hubbed.
rolmops
Re: Spun Prop ?
Hello.<br />Did you take your prop off?<br />You may have picked up a a few yards of fishing line and that will do that sort of thing.<br />Good luck.
snard
Re: Spun Prop ?
I had the same symptoms last summer and it turned out to be the hub which was spun. I could not move it by hand but the force of the water/motor would.
50horce_force
Re: Spun Prop ?
Really i had the prop re hubbed the a bought a new one and something it still slipping WHAT IS ITTT????//?????????????
Spidybot
Re: Spun Prop ?
Hey 50horce_force,<br /><br />Adding your own questions to a thread started by someone else ain't too smart.<br /><br />You have posted your question under a separate topic and so it should be. Otherwise it becomes impossible to follow a thread and we don't know where to answer = you don't get any replies.<br /><br />Stick to the topic you started.
Spidybot
Re: Spun Prop ?
No offence, just want to help you get the most out of it.
