I have a 1987 Mercury 70 hp. When I try to start it it takes significant pumping of the primer bulb and eventually with lots of choke it will run.The motor has recently had a rebuild so I am running double the oil and lots of smoke comes out. I need to give it lots of throttle advance to keep it running in neutral. Once I bring the throttle back to shift it dies out. While it's running on throttle advance it revs fairly high, I'm guessing 2000 rpm, but, I don't have a tach. Even at those revs it coughs every 2 seconds or so. It did run OK a few days ago (still had the tough starting problem) but all of a sudden it sputtered to a hault while running 3/4 throttle and did not start easily after that. The primer bulb does not seem to be as full as other boats I have run. Lots of cooling water is happening. The boat has a built in tank. My first theory is that perhaps the fuel line has a blockage somewhere, but, would that bring about the symptoms I have described? The coughing worries me. Would it be a reasonable next step to try and run the motor off of another tank/gas hose? Sorry for the long post, but, the number of words are a reflection of my frustration with my boat
