Hello. <br />What i have is a 1987 mercruiser 3.0 with alpha 1 drive. The problem im having is a squealing noise when i first start the motor. It lasts for about 5 to 10 seconds. The exact same noise comes when i try to use the trim with the engine running. The trim does not squeal when the engine is not running so i am assuming its not the trim motor. Also when i go from reverse to forward sometimes it makes the noise. It almost sounds like a belt slipping but its not my belts.I dont get the noise at any other times. Any suggestions would be great.
