Re: Squirly tach
I'm having the same troubles you've described on my E150STLCEM (an '89). This started last season and has gotten progressively worse, and sometimes the tach doesn't work at all now. I am interested to hear the replies you get to this question. I am having other intermittent ignition problems (randomly losing spark to 1 or more cylinders at any given time), so I am replacing parts to try to fix that first. I replaced all 6 ignition coils yesterday. Didn't figure that would fix it, but the old ones were cracked and I'm afraid they could be shorting to the block (if not now, soon!). I just ordered a new power pack today. Hopefully, if my current pack IS bad (i.e. this fixes my spark problem), a bad rectifier/regulator won't kill my new pack in short order. I'm guessing the guys here will tell you how to check your tach and your rectifier/regulator, as I understand that this is what supplies the signal to your tach. Good luck!
