So this bozo put over $150 of marine grade 3/4" on top of a rotten floor with the vinyl. When I say rotten, I mean I can pull pieces by hand. The vinyl is the only thing holding the disintegrating original deck..........lol
On some of the models, like mine, the sidewalls have the flange that screws into the deck. Since you can't walk on the floor without falling in, I need to get large pieces out for safety reasons.
Would anyone suggest just loosening the screws(not removing) that hold the flange down to release the deck, yank it out, and move on?
I have also seen a few resto pics where the floor was removed leaving the consoles intact. I plan on removing them anyway for a custom rebuild, but just want to get the cockpit cleared. the flotation is the white stuff, not the pour in and what I have seen so far may allow me to reuse it?
Working a little backwards on this project taking advantage of the weather. Spent 2 days with orbital and removed the mess prior owner made down to his primer using various grits. She went from metallic silver to two coats of white primer and ready for topcoat before she gets inside. Did the boat, not the transom or hull yet, that will be after winter when the engine gets pulled.
