SS Propeller ?
cloumar
Hi guys,<br /><br />Simple question for some expert about replacing my Aluminium prop. by a Stainless one:<br /><br />If my boat is doing OK now in term of max. RPM, hole shot and top end, but I want to simply go with a Stainless Steel prop. for better performance, do I need to change anything with diam and pitch or remain with the same size of my aluminium one ??<br /><br />Thanks <br /><br />Smoky ;)
ob
Re: SS Propeller ?
Stay with the same dia and pitch.
RatherBFishing
Re: SS Propeller ?
Do you get better performance out of a SS prop or does it just hold up better? If anything I would think you would get better performance out of the lighter prop.
cloumar
Re: SS Propeller ?
Well, I heard that there is less flex with a SS prop. which it turns to be les slippage !!!<br /><br />I may be wrong !<br /><br />Smoky
ob
Re: SS Propeller ?
SS props are generally double cupped where the aluminums are not affording better bite at higher mounting heights and less slippage in tight turns on plane.The overall blade thickness is thinner and thus cuts the water more efficiently.
lakeman1999
Re: SS Propeller ?
When I replaced the aluminum prop with a stainless, it was like immediate hop up, the difference was very noticable from the first moment. :D :D
evin300
Re: SS Propeller ?
I believe you would want to go down 2" pitch when changing from aluminum to SS.
chris in va
Re: SS Propeller ?
I changed from a composite 4 blade at 20p to a 21p stainless, and I gained 12mph top end but still retained good holeshot, if not better. <br /><br />I can't believe the difference. From 38 to 50mph really amazed me.
