stabilizer
mudbug141poppy
is there a such thing as putting to much stabilizer in your fuel tank when winterizing. motor is1998 mercury 50hp 4stroke bigfoot
robert graham
Re: stabilizer
I don't think you can put "too much" stabilizer, but I use a bit more than recommended on the container, all :)depending on how long your motor will be laid up. It's also a good idea to drain each carb float chamber just to be sure all water and debris is gone. Look for a drain screw near the bottom of each carb, hold a rag under it to catch it if you drop it. Good Luck!
TRAILN
Re: stabilizer
How much too much do you think you added? A few ounces shouldn't matter much. I would leave it over the winter and in the spring time remove fuel and replace with fresh.
lncoop
Re: stabilizer
Clearly states on the bottle there are no adverse effects from adding "too much"; other than the adverse effect on your wallet, which is NOT clearly stated on the bottle.:p
robert graham
Re: stabilizer
If you relly want to do something nice for your motor, install a Walmart/Attwood Fuel/Water Separator Filter($27) on your transom to filter out water, dirt, trash, whatever from ever reaching your carbs. That filter and the fuel Stabilizer, and you will eliminate most fuel-related problems. And fuel related problems account for at least 2/3rds of motor issues. Good Luck!:)
mudbug141poppy
Re: stabilizer
Well trailn i haven;t put to much in yet,was just thinking more would be more protection and why would i have replace the fuel in spring,why couldn't i burn it through the engine
mudbug141poppy
Re: stabilizer
Robert i was looking at thewater separator at walmart ,(seasence)was woundering what micron rating it was,it didn't say on box.would i have to take out inline fuel filter if i added the water separator
robert graham
Re: stabilizer
Just install it on your transom, leave the under-cowl mounted filter in place as a back-up just in case some trash gets past the big filter. I don't know what the micron rating is but it works like a charm, and I just unscrew mine now and then, dump it out, and screw it back on. I finally put a new cartridge on after 3 or 4 years, but I hack-sawed the old one open to see what was in it and it looked pretty much like new inside. Good Luck!
TRAILN
Re: stabilizer
You could.... A few years ago I added way too much to my leaf blower and it didn't run right. I replaced that gas with fresh fuel and its been better since. I don't know how volatile and flammable fuel stabalizer is but I'm guessing too much mixture won't ignite aswell.
cdn-pk
Re: stabilizer
i remember reading either on stabil or motormaster that for londer term storage (>6 mon) to double the amount.
