I own a 12'9" fibreglass boat which is fitted with a 55HP Yamaha weighing 90 kilos. Boat is driven from the stern seat by means of a central console. The boat has a seat amidships wherein the battery is located, a bow seat wherein the standard 25litre fuel tank is located and a forward anchor locker containing an anchor and a quantity of marble granules for ballast.<br /><br />The boat had a raised bow and was initially porpoising and cavitating significantly which situation improved considerably with the marble granules up front and the manual tilt set to the furthest inward position. However it still does not get out of the hole completely or in simpler words it does not plane smoothly on the cavitation plate.<br /><br />Prior to putting in the marble granules as front ballast I steered the boat from the seat amidships and the boat planed perfectly with no effort required to get on the plane.<br /><br />I would like to get rid of the marble granules since when a reasonably sized person sits on the bow seat and the boat is driven slowly it takes in water even in calm seas.<br /><br />As a substitute and to ameliorate this state of affairs I am thinking of fitting either a Doel Fin or a Whale tail / peramtrim stabilizers or smart trim tabs.<br /><br />I weigh as much as the outboard - 90 kilos !<br /><br />I would be very grateful for advice on which is the most suitable and effective option / course of action.<br /><br />Thanks
