Basically Im going to be mounting my sidepods (which have no bolts and are screwed into the threads in the block) And my water jacket cover which is a nut and bolt combo.<br /><br />I am thinking of dipping each bolt in a high temp corrosion/rust resistant grease before screwing them in so in 5-10 years if need be i can unscrew them (i use my boat in salt water 100%)<br /><br />Do you think this is a good idea or is there something better? <br /><br />I also have this Gasket Maker RTV thing and i have scratched all my covers/pods where the gasket plus the block a bit because of prying and taking the old gasket off. Im thinking of putting the RTV which is resistant to 300deg and has corrosion resistant qualities plug a brand new gasket.. Will this help?<br /><br />Thanks guys BTW my motor is a Mercury 650cc Thunderbolt 1970.. 4 cyl and 65hp
