Stainless steel cleaning tip...
Mark42
Don't make the same mistake I made cleaning SS. I took years of paint and crud buildup off of all the stainless screws with a wire wheel on the bench grinder. They looked great, but after the first trip to the water, they showed rust stains all over them. I took all the screws out and cleaned them on a buffing wheel. Nice and shiney, and they have not showed rust.<br /><br />I think the rust was from a thin coating of steel left on the screws from the wire wheel cleaning. That thin layer of steel rusted.<br /><br />So, when cleaning stainless hardware, be sure to buff it out if you used a wire wheel on it.<br /><br />Mark.
snapperbait
Re: Stainless steel cleaning tip...
Great tip... :) <br /><br /> I have encountered this when cutting stainless tube for swim platform supports.... Used a sawsall w/metal cutting blade to cut the tube to length, and used regular sandpaper on a grinder to clean up the ends after the ends were flattened out and bent.... Rust was forming after the first trip...
I've had Great Luck using SSteel Brushes in my 4"Grinder,<br />For Cleaning Both SSteel,+ Aluminum........<br /><br />Cutting SSteel is Always a Problem for me........
always use stainless materials to polish, cut etc. on stainless steel. anything else will contaminate the steel, and rust will follow! Also, once buffed to a nice shine, clear coat it with a good clear and it will stay shiny, longer!
