paulcierra26
- Joined
- Jan 7, 2009
- 18
I have a set of Stainless Steel "Duoprops that I aquired for my Volvo Penta DP-S Leg.
The props do not have any collision damage but one prop has a salt water corrosion hole about the size of the end of a pencil and the other prop has a corroded section on one blade about the size of a dime with a couple pin holes that go right thru the dime sized area.
Can these props be repaired?
Other than the couple of corrosion holes the rest of the props / blades look fine, at least to my untrained eye.
Is this kind of damage normal ?
I wonder why 99% of the rest of the prop surface area looks near new but yet still succombed to small very specific damage to the areas as described above.
